cant get outta park
Old May 18, 2010 | 08:19 AM
1sikhatch's Avatar
Default cant get outta park
i just picked up a ek auto but i cant get it out of park unless i press the interlock thing by the gear selector. how doi fix thi?
Old May 18, 2010 | 08:37 AM
EFbomb's Avatar
Default Re: cant get outta park
make sure the brake switch is working(check your brake lights), and check that the shift lock solenoid is getting voltage when you press the brake . It may need a new gear selector switch.
Look in the FAQ for wiring diagrams.
Old May 18, 2010 | 03:55 PM
1sikhatch's Avatar
where is the shift lock solenoid? and i checked my brakes and the lights are fine
Old Dec 3, 2010 | 07:17 AM
dhouse260's Avatar
The shift lock solenoid is right next to the "P" on your gear selector (if it's an automatic). You have to pop the cover off and use a key or other thin object to press the override button in. I'm having this same problem with my 2003 Accord except the brake lights are not coming on. That leads me to think it is either the brake switch gone bad, or the fuse under the hood that is preventing from me shifting without the override. Anyone have any thoughts on what this could be?
dsjetergirl
44
Apr 12, 2015 07:31 AM
losthitchhiker
Jan 23, 2012 10:19 AM
sageuvagony
Mar 25, 2010 05:05 PM
DC5_lov3r
14
Aug 7, 2007 01:24 PM
crystalclear444
May 10, 2004 04:44 PM
