Direct port on performer X manifold
Has anyone ever do a direct port on a performer x intake manifold using the embosses for 8 injector setup? Im thinking of using the NOS annular discharge nozzle and tapping them into the injector embosses. or should I go with the 90 degree fogers and tap them in closer to the intake ports? I fugured the annular nozzles wont disrupt the flow in the runner because it is at 30 degrees pointing toward the port. If any one did or seen a setup using the extra 4 embosses on the bottom of the manifold, please let me know what nozzles were used and where they were tapped into. Thanks!
rjay8604
Welding / Fabrication
17
Jan 26, 2006 12:05 PM
