Motor crank but no fuel coming
Old May 17, 2010 | 05:23 PM
YangFlavor's Avatar
Default Motor crank but no fuel coming
i swap a d16z6 motor, I started it up but no fuel coming? i have full tank gas. I dont hear the fuel pump prime. so i went n bought a fuel pump and put it on but same thing happen. what is wrong? any help would be great
Old May 17, 2010 | 05:28 PM
1992Si's Avatar
Default Re: Motor crank but no fuel coming
Clean the ecu ground wire that is connected to the thermostat housing. Don't not paint anything in it's ground path. You may need to move that ground to the head for a unpainted surface.
Old May 17, 2010 | 06:43 PM
TylerB's Avatar
Check the main relay as well.
Old May 17, 2010 | 08:10 PM
itsnotfast's Avatar
x2
Old May 17, 2010 | 11:40 PM
YangFlavor's Avatar
i try and see if it works
ek_b16
Jul 2, 2009 07:53 PM
illassek9
Jul 14, 2008 12:04 PM
The Dirty EJ1
Jul 8, 2007 05:27 PM
Hella_Fresh
Mar 6, 2007 10:15 PM
Pman92
Dec 9, 2006 04:56 PM
