EXHAUST stuff - Civic/Integra piping, mufflers, cats, OEM LS manifold - *RI*
Old May 17, 2010 | 02:34 PM
94CivicSi's Avatar
Default EXHAUST stuff - Civic/Integra piping, mufflers, cats, OEM LS manifold - *RI*
I've gotta get rid of these exhaust parts. MAKE OFFERS. All parts located in Providence, RI.
__________________________________________________ ______________________
There's enough piping here to assemble your own Civic or Integra custom exhaust. Take it all, or just take a piece. I've got:
- 2.5" stainless exhaust front section that connects to the cat. Mandrel bent by VRS.
- 2.5" stainless "S-bend" section w/ resonator. I cut off the front 3-bolt flange and part of the hanger. Flange is 2" OEM where it connects to the muffler.
- 2" -> 2.5" muffler bend. Run an aftermarket muffler w/ stock piping. I had it on my EK coupe, but you can loosen the clamp and change the length for a hatch or Integra.
OBX Twin Loop stainless muffler. Used but in good condition. I was going to paint it black, primed a section on the bottom, then stopped.
Basic Magnaflow muffler. Put it on your beater.
stock B18B1 OBD2 exhaust manifold It has new gaskets in the junction. I don’t have bolts for the heat shield.
used aftermaket catalytic converter w/ OEM 2” flange It throws a code in an OBD2 car. MIGHT work in an OBD1 car, but can’t make any promises.
used aftermarket OBD1 catalytic converter w/ OEM 2.5” flange. You could add an o2 bung to convert it to OBD2.
MAKE OFFERS!
Old May 18, 2010 | 04:16 AM
94CivicSi's Avatar
Default Re: EXHAUST stuff - Civic/Integra piping, mufflers, cats, OEM LS manifold - *RI*
TTT
Old May 19, 2010 | 12:23 PM
94CivicSi's Avatar
bump
Old Jun 3, 2010 | 06:53 AM
94CivicSi's Avatar
Unfortunately, I've still got all of this stuff. Hit me up if you think you can use any of it.
Old Jun 3, 2010 | 07:10 AM
bluxberryxhaze's Avatar
bump for RI! and a white si..
NathanDC4
Mar 27, 2016 04:55 AM
akire45
Jun 29, 2009 04:55 PM
crispchris
Northern California (Sales)
22
May 10, 2009 05:09 PM
civic2sick
Welding / Fabrication
14
Feb 14, 2007 09:47 AM
BaYaReAJDMjunkie
Mar 30, 2005 11:43 AM
