02-04 RSX Type S stock/aftermarket parts J's Racing, Mugen, T1R, Top Fuel, etc.
Old May 17, 2010 | 10:25 AM
PliggityPB's Avatar
Default 02-04 RSX Type S stock/aftermarket parts J's Racing, Mugen, T1R, Top Fuel, etc.
So I have a bunch of stock parts in my garage from a now almost 60k mile old '04 RSX Type S for sale... This is all the original stuff and some aftermarket parts that I personally took off my friends car, which I originally installed, and installed new stuff in place of it. Parts are used, NOT NEW. I will try to be as honest and descriptive as possible and if you have any other questions or would like some more or specific pictures of anything, please let me know! All prices are OR BEST OFFER! I am NOT accepting any trades, so please do not offer! Willing to ship parts at buyers complete and 100% expense, only to the continental US.
STOCK PARTS from an '04 RSX Type S
- pair of USDM OEM chrome housing headlights with low and hi-beam bulbs. The lenses have been buffed and polished up, very fresh! These have all mounting tabs in tact, no major damage, defects or loose parts. Super clean! These were replaced with a pair of factory JDM ITR HID headlights. $150
- black plastic "A" coil pack/plug cover, was removed when the car was bought. $20
- gray plastic iVTEC cover for over the fuel rail and intake manifold, also removed when the car was bought. $40
- factory black firewall-to-struts reinforcement brace. This was removed for the install of a Carbing 3 point front strut bar. **will fit underneath Mugen front strut tower bar** $50
- factory rear lower control arms w/stock bolts if necessary. Replaced with Skunk2 rear LCA's the same time the coilovers were installed, just before the 50k mark. $80
- 02-04 5 spoke stock Type S 16x6.5 rims w/less than 3000 miles on Hankook Ventus HRII 205/55R16 tires, siped by Les Schwab. Treadwear is 340, Traction A, and Temperature A. No camber wear. No gouges. No bubbles. Safe and new enough for your own Grandma! Car has 17's on it now and these will not fit over the factory JDM Brembo ITR brake setup. $400
- factory suspension intact - Front and Rear struts and springs, assembled. these have less than 50k miles on them, were removed and replaced with Tein full coilovers. No leaks. No damage. Perfectly operating, unabused factory setup. $120
- Front and Rear 5 lug factory Type S brakes and hubs assemblies. Will include factory break lines, front lower control arms, hubs, rotors, and calipers. The back left hub has a busted wheel stud but I have another hub with 5 wheel studs in it to include with everything. $300
AFTERMARKET PARTS from the same '04 RSX Type S:
- T1R Type One Racing Sportsexhaust. 63mm SUS304 stainless steel cat-back system, will see TRUE DYNO GAINS. Was on the car for about a year, then replaced with a full Toda Power Race exhaust. Has a heat treated titanium exhaust tip. Bolts up to stock catalytic convertor or most 3-bolt downpipes. Very MINOR MINOR scratches, NOT DENTS, on B-pipe as are most lowered RSX exhausts. No major damage or dents to any of the pieces. Was bought new for over $750. It came with a silencer plug for the tip, but I have to see if I can find it, as I just recently moved. Only $400
- J's Racing engine torque damper. Used for maybe 20k miles? Green version. Still has sticker in-tact. Comes with all necessary hardware to install! $100
- AUTHENTIC!!! Mugen Power front strut tower bar. This bar allows use of both the J's Racing engine torque damper and the factory black firewall-strut bar in conjunction with the Mugen bar installed. Recently polished. There is a small knick in the sticker in the center of the bar in the "P" of "Mugen Power". No cracked welds, or scratches or gouges. Slight blemish on the outer ends of the bar from the layer of fire-retardant attached to the underside of the hood. $225
- Top Fuel zero1000 JDM "piston" shift ****. Slightly used. Some of the design is starting to fade off of the top of the shift **** where the zero1000 logo is. Still have box, and includes locking nut, thread pitch is 10x1.5mm. $20
All prices are OR BEST OFFER, and DO NOT include shipping. If you would like more, or specific pictures of anything, please free to let me know. Parts are located in Seattle, WA and I am willing to meet local people within a reasonable distance from me. Email me at pliggity@gmail.com for best reply! Thanks for looking!
Old May 17, 2010 | 10:30 AM
PliggityPB's Avatar
Default Re: 02-04 RSX Type S stock/aftermarket parts J's Racing, Mugen, T1R, Top Fuel, etc.
... continued:
also have a set of 225/45R17 Hoosier D.O.T. rain tires, never mounted before! Worth about $1000 from tirerack.com, plus the wait and everything! Get them here for $800!!!!
More pictures upon request! Parts are off the car and ready to be sold!! Again, buyer covers shipping cost!
Thank you for looking.
PatB
1QwIkEf
Jan 13, 2010 08:54 AM
Unlimited_Moto
Acura TSX
Mar 3, 2008 04:39 AM
formervendor
Feb 8, 2008 12:29 AM
-slow ej-
Aug 23, 2004 06:17 PM
AJ PwR
Aug 4, 2001 02:26 AM
