I need some BBS RS info...
Old May 17, 2010 | 08:48 AM
J.WOLFE~v1.0's Avatar
Default I need some BBS RS info...
i bought these last week and have been using the stock lugs that dont fit 100% correct, i was wondering what the correct style of lug acorn/cone and any specific lugs you guys out there have used that have also owned RS's.
also these are 15x6.5 +33, i will need hub centric rings as well. i know the stock hub size on my car is 56.1 but whats the hub size for these? im lazy to take them off right now and measure, plus its raining
thanks
Justin
Old May 17, 2010 | 01:45 PM
r.wright's Avatar
Default Re: I need some BBS RS info...
every wheel and car is different therefore you will need to remove the tire and measure the distance w/ a caliper tool.
all bmw/vw cb for 4x100 was 57.1mm so it might be that but i doubt any one can tell you that for a fact since every wheel is made different esp the rs.
so are you saying the lug nuts do not seat correctly? or the lug nuts dont clear your hub caps?
you can use muteki open ended short lugs ASSUMING that the seat on the rim is conical(cone shaped)
http://i1.frsimg.com/images/detailed...eki_Open_1.jpg
Old May 18, 2010 | 08:06 AM
they clear the hub caps but i dont feel they sit 100% on point, like they dont go the complete way down, and yea now i have a problem where i unscrew the center cap and the piece behind it that covers the lugs will not come off, i tried prying it but not much seems to work, these are just supposed to come right off and its got me stumped
Old May 19, 2010 | 09:43 AM
Captain Key!s's Avatar
x2 on the Muteki open ended (short) lugs. They seat perfect and the clear the center cap collar with no issues. The go for around $50 a set depending on where you go. I got mine from inline-four.
Dingrz
Jul 12, 2013 09:23 PM
Dingrz
Jul 6, 2013 10:18 PM
drktorn
Jan 24, 2013 08:15 PM
Georgio
Nov 30, 2012 07:40 AM
Ek_Eli
Dec 21, 2011 05:45 AM
