Stock Throttle Body -- Size??
Old Sep 12, 2002 | 06:58 AM
bfrank81's Avatar
Default Stock Throttle Body -- Size??
What is the size of a stock throttle body on a '91 Si HB?
Thanks,
Old Sep 12, 2002 | 08:18 AM
bfrank81's Avatar
Default Re: Stock Throttle Body -- Size?? (bfrank81)
** BUMP
Old Sep 12, 2002 | 10:59 AM
Lamchop0000's Avatar
ok i just measured my 90 crx si throttle body...
outside diameter is 2 9/16"
inside diameter is 2 5/16"
hope that helps
Old Sep 13, 2002 | 04:57 AM
bfrank81's Avatar
Default Re: Stock Throttle Body -- Size?? (lamchop0000)
OK. So when I convert 2 5/16 into mm I get 58.73761747523495
Round that off to a 58 - 59 mm throttle body.
Is that correct?
Thanks for the measurements!
Old Sep 13, 2002 | 11:07 AM
civbeater90's Avatar
no stock is smaller than 58 mm.i believe 54 mm.
Old Sep 13, 2002 | 12:06 PM
slowman's Avatar
I took way too long
Default Re: Stock Throttle Body -- Size?? (civbeater90)
Whats the size of the Y8 Throttle Body?
Old Sep 13, 2002 | 01:31 PM
Hondacar's Avatar
Default Re: Stock Throttle Body -- Size?? (slowman EF)
I would have to think that you would want measure the end by the throttle plate. I have the original tb of my ZC and in the throttle plate area I get 2.169-2.170 = 55mm
Old Sep 13, 2002 | 03:17 PM
solorex's Avatar
Default Re: Stock Throttle Body -- Size?? (Hondacar)
Stock D-series throttle bodies are all 55mm.
Old Sep 13, 2002 | 04:17 PM
sicivic's Avatar
Default Re: Stock Throttle Body -- Size?? (solorex)
Solorex is correct.
Old Sep 13, 2002 | 06:13 PM
Default Re: Stock Throttle Body -- Size?? (sicivic)
i measured the lip of the throttle body not the acutal plate diameter.
Old Sep 13, 2002 | 06:22 PM
bfrank81's Avatar
Thanks!
Old Sep 13, 2002 | 06:23 PM
MrTodd's Avatar
Y8 is a 58mm I believe...
fg2si!kid
Acura TL, RL & ZDX
Jun 26, 2008 03:57 PM
LU
Nov 10, 2006 10:54 PM
Project_Civic
Apr 3, 2005 12:23 PM
CRXRageD
Apr 19, 2002 08:48 AM
