DC Gauge Cluster Bulb UPGRADE
I've searched and found what replacement bulbs to use in my gauge cluster but I'm curious what I can use to actually make the display brighter?
Seems like superbrightleds.com would be a good start but I'm not sure what which ones to purchase as I've never had the cluster out before.
Could anyone give me a hand here?
bought mine from autolumination but you can get it anywhere I guess, larger bulbs are 194, and smaller bulbs are 74, get the multi-firing ones meaning they have the lights on every side. This is what mine looks like
don't want it to be too bright or else they might be a hazard while driving
i went to autozone got some amber 194 thanks LS VTECteggy took out the bezel unscrewed the cluster unplug the wiring and removed the 3 big bulbs that run in the middle across and that was it
I'm just going to get them at Walmart. I installed amber bulbs in my clear corners the other day, and I found out the bulbs are actually the same size in the cluster and in the corners (the little sidemarker lights).
https://honda-tech.com/forums/acura-integra-6/diy-purchasing-leds-integra-gauge-cluster-uber-detailed-diy-1942094/
I used this thread. There is a website that can give you different color options. I opted for the super bright white. If it is too bright you have a dimmer and can adjust to your liking. I tried the blue and try just were not bright enough. IMHO.
Post an update with pics of your upgrade!
https://honda-tech.com/forums/showthread.php?t=1942094
