Fuel Gauge Problem
ok so i've just wired some LED strips for my gauges. I soldered the wire onto the bulb connectors. Now my gas/fuel gauge is broken. The temperature, tach and the speedo works fine only the gas gauge is broken. The gas gauge needle is staying at full and i know for sure its not full in gas. I've checked the solder and it is not where it is not suppose to be. I've tried moving the needle slowly to empty and turned on my car and it keeps going back up to full slowly. It worked perfectly fine before Idid the LEDs. Is there anything i can do find the problem or do some kind of reset or troubleshoot?
