looking for bearings... for an F20b
Old May 16, 2010 | 04:47 PM
gabR.'s Avatar
Icon6 looking for bearings... for an F20b
so I managed to spin a bearing on my new swap... that I haven't got to drive yet. I need to know what main bearings and rod bearings to use for it. Also, if I got lucky enough to ruin the crank, what crank do I use. While I'm at it. what crank pulley can I use to regain power steering? i know I need and h22 PS pump, bracket, and a spliced hose to fit on my 96 Accord LX. Help this poor soul get his sedan back on the road.
Please don't give me info that you "think" is right. that became a costly problem with my crx when I was offered "proven" info. Thanks for reading and providing REAL specs.
Old May 16, 2010 | 04:56 PM
champcoupe's Avatar
Default Re: looking for bearings... for an F20b
you can use the crank pulley from the motor you pulled out of the car. which f20b??? dohc vtec or non vtec????
Old May 16, 2010 | 05:10 PM
gabR.'s Avatar
dohc vtec... why bother with worse motor? i only chose this over h22 because of the "that's not a h22?" effect it has on people. well, those who only deal with b and d series.
Old May 16, 2010 | 05:14 PM
champcoupe's Avatar
ok. the h22 crank is the same. you need to pick up a set of h22 bearings, main and rod.
Old May 16, 2010 | 05:29 PM
gabR.'s Avatar
alright thanks for the advice. I will wait for more input though, I was told F23 main and for rod, b16... wild huh! i do know that h22 and f20b are a little different internally, IDK yet, making me a bad owner for being so ignorant on what I do have
Old May 16, 2010 | 07:17 PM
champcoupe's Avatar
f23 uses the same main bearings as h22, and b16 uses the same rod bearing as h22. you can check the part numbers with Honda parts department.
Old May 17, 2010 | 03:28 AM
hondamark35's Avatar
false
false
i checked the part numbers.. not the same.
F20B uses F23 mains and B16 rod bearings like the op said. i don't have any B16 parts handy, but i do have F23A1 crank and rods and F20B crank and rods laying around so i've checked first hand.
Old May 17, 2010 | 11:24 AM
crx_91si's Avatar
I don't know how of this applys to the F20b but to reatin my PS with my H23A, i had to
- swap the crank pulley from my F23
- get a 97+ Prelude PB bracket and bolts
I didn't have to mess with splicing the high pressure hose or changing pumps and ****. I would think it would be the same for your F20
Mike
Old May 31, 2010 | 09:23 PM
HeikDiesel's Avatar
Ok to clear some things up the 97 f20b had a 50mm main journal crankshaft whereas the 98+'s had a 55mm journal. The rod journals are the same as a B series so depending on your year you either need h22 or f23 mains, and b series rods
cvcrtonv
Feb 8, 2008 07:14 AM
AndyD
Nov 23, 2003 02:42 PM
