How many Coolant or Water Hoses in Honda Accord 1994 EX
Techs,
Any information how many water or coolant hoses are there in Honda Accord 1994 EX and how will you replace the small hoses i-e can you use regular fuel hose or only by pass hose or something else and what size???
Any input regarding that will be highly appreciated
you can't just see the hoses? theres obvious a upper and lower rad hose. Should be another on the backside on the transmission side if i remember correctly. just look at your hoses and see where they go and do your best to identify. I'd pick up a haynes manual. And as for using fuel line to sub for coolant line, it will work but the fuel line usually has a lining in it compared to the coolant hose although fuel line takes alot of pressure because of its use.
total including radiator hoses, heater hoses and bypass hoses i think there are 14 with the oil cooler and 12 without.
i remember this job being a pain the first few times i did it, bu after some practice and learning the best pliers to use it gets pretty easy. still time consuming though.
It took me ~1 Hr to replace a hose which goes from Throttle Body to IACV and I replaced it with the Fuel line Hose it was bit tough for me to put it but any how I put it there and its bit lower on these steel pipes I mean its not properly seated till the end of steel pipes( Will it be a problem????)
So far I do not see any leaks but my concern and question is that how you guys replace these small hoses I mean which hose you guys normally use???Because every time I cant buy Bypass hose(~$11)
Please see attached picture
EG-SIXV-TEC
Jun 11, 2010 01:35 AM
BoombasticSloth
Jun 1, 2007 08:44 AM
