Are 1990-1993 Integra Axles Universal?
Old May 15, 2010 | 05:11 PM
avargas28's Avatar
Default Are 1990-1993 Integra Axles Universal?
I have a 1990 Integra that needs a new passenger side axle. I plan on buying a used one but I want to make sure it will fit.
Should I look out for anything? Or will a 1993 fit in mines? And does it matter if it came out of a auto or manual car? Mine is a manual tranny.
Old May 15, 2010 | 05:16 PM
MD426's Avatar
Default Re: Are 1990-1993 Integra Axles Universal?
It should fit, only difference from 90-91 and 92-93 was OBD0 to OBD-I. Only thing to look out for is with ABS and with out ABS. Something to look out for is the boot, if worn or torn then it's not too good. Bend the CV and feel for grinds or a gritty feel. and if the splines are messed up.
Old May 15, 2010 | 05:20 PM
avargas28's Avatar
I noticed when searching for an axle is the whole ABS/No-ABS thing. How do I know if I even have ABS? I'm a little confused about that. Mine is a 1990 LS.
Old May 15, 2010 | 05:55 PM
MD426's Avatar
ABS were only available with the GS and GSR models. the RS and LS did not come with ABS.
Old May 15, 2010 | 05:57 PM
avargas28's Avatar
ok, cool. Does it matter whether the axle I get has ABS, meaning - if I get one that has ABS, will it matter? The seller doesn't specify if it does or doesn't.
Old May 15, 2010 | 06:07 PM
MD426's Avatar
The ABS axle has a magnetic sensor it in where are the non abs does not. You can use an ABS axle for non ABS but not the other way around.
Old May 15, 2010 | 06:22 PM
avargas28's Avatar
cool man, thanks.
Old May 15, 2010 | 09:47 PM
hybrid90's Avatar
ABS axles have a metal grooved ring at the end. You can use an ABS axle on a non ABS teg.. just use a screwdriver and knock the ring off if you're **** about stuff like that... but really, you can just install it as is...
EG-SIXV-TEC
Dec 24, 2008 08:46 AM
The Flying Dutchmen
Jun 9, 2005 07:56 PM
Integra99
Jul 7, 2004 04:48 PM
