port and polish head or no
Old May 14, 2010 | 11:32 PM
roycivic92's Avatar
Default port and polish head or no
does any one have a before and after experience. my build
1.b20b block and crank,eagle rods,itr spect pistons
2.b16 head,skunk2 stage2,550cc inj ,s100
im slevving the block for sure, but p&p im not sure. i only drive the car on the week ends.would it be a big jump in power.
Old May 15, 2010 | 06:22 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: port and polish head or no
define "big".
Old May 15, 2010 | 06:44 PM
Scott_Tucker's Avatar
It depends on whether the person doing the work on the ports knows what they are doing. If they don't have a flow bench don't bother. It also depends on whether the person designing the engine knows how to tie into the other parts to take advantage of the porting and polishing.
Old May 16, 2010 | 07:17 AM
baysic r's Avatar
^^^ i second that....make sure the cat who is doing the pnp knows his stuff...**** for 100 i can do it for you but it dont mean it's worth it...
Old May 17, 2010 | 12:09 AM
roycivic92's Avatar
alaniz technologies. when i say big is if i would see a big bump in power in the dyno.
Old May 17, 2010 | 06:11 AM
neverstop's Avatar
I don't see why you'd sleeve the block and not port the head. a good port job for a motor like that is probably worth at least 10-15hp if done by someone good.
Old May 17, 2010 | 06:18 AM
How many horsepower is 'big'?
Old May 17, 2010 | 04:48 PM
airmaxbri's Avatar
do it. Because if you build this motor without porting it, you'll regret it and want to port it down the road anyways. It can save you money in the long run by doing it now. Just make sure it's ported from a reputed porter
Old May 17, 2010 | 06:24 PM
SisterFister's Avatar
how much would it be to port and polish a d16 head
Old May 17, 2010 | 08:35 PM
roycivic92's Avatar
ok my setup
85mm itr spec pistons,eagle rods,ls crank,b16 head,p73 manifold,68mmtb,750cc injectors,s100,skunk2 stage 2 cams,supertech vt. hoppng to get 230hp at least or near that area.
Old May 18, 2010 | 02:12 PM
00Red_SiR's Avatar
All Motor Mentor
ok my setup
That's not really an answer. How much is "big"? 5hp? 10hp? 15hp? 20hp? more?
How about you contact a head porter and find out?
rhymeshark916
Northern California
12
Jan 11, 2012 01:54 PM
chaokongz
Jul 4, 2009 01:06 PM
OMG THE GOGGLES
10
Sep 19, 2008 09:38 PM
itr1236
Oct 6, 2007 12:19 PM
ITRnorway
Nov 16, 2006 01:54 PM
