Bondo Meathod/Info/Tips
So if you are familiar with auto repair or are new to it, without a doubt you have at least heard the word "Bondo" thrown around, for those of you who have purchased Bondo and are looking at it with a confused face because there are little to no instructions, here are some tips on how to use it, how it works, so on.
Bondo is a company offering different auto body repair materials, from fiberglass resin, auto body filler, auto body filler "gold", spot glazing puddy, and fiberglass jelly.
THE FIRST STEP IN USING ALL OF THESE WILL BE THE SAME, CLEAN THE AREA ABOUT TO BE REPAIRED AND RUB OVER WITH A HIGH GRIT SANDPAPER FOR ADHESION PURPOSES.
FIBERGLASS RESIN
Best to be used on fiberglass or plastics, such as bumpers, side skirts, so forth and so on, use your imagination. for this you will need to get the resin, a resin mat, and a putty knife. This stuff is a HUGE pain in the *** to work with, its not suggested by me.
First off take a good look at what you are planning on using this for, cut a piece of the mat to size of area being used on, make sure its larger than 2 inches square, or well it wont really work too well, also it will seem as if its becoming unthreaded, dont fret too bad, its not a matter of life and death, it happens.
To use this place mat and hardener together on clean surface, preferabely one such as a paint roller plastic thing. mix hardener and resin together, ratio of 5 resin, and 1 hardener, then dip the mat into it. now that your mat is drenched within the fiberglass apply to the area of car to be used on, then use putty knife to smooth the mat down so that you dont have weird areas to work with that are as my friends and i refer to as "cottage cheese ***" because there are multiple dimples which trust me, are no fun to sand.
Once the mat has dried sand over to smooth, i suggest 140 grit sandpaper, takes off a decent amount, but still retains its shape without scratching like 60/40 grit would.
If you happen to sand down too far and reach the the fiberglass mat, its just going to become a more tedious task unfortunately, apply more fiberglass without the mat to the area in which is exposed, then redo all the fun steps of sanding.
AUTO BODY FILLER/GOLD
In my opinion this is the easiest form to work with, take your time with this, best for use on bare metal, can also be applied to fiberglass. In my personal opinion there is no visible difference between the two types. For this process all you need is a set of putty knives, a base to mix the materials, try and use something with as little pores as possible (stay away from wood, cardboard, hell no to paper). This comes with a coordinating thing of red cream hardener, don use it all at once that would be idiotic.
The downfall of this is that it will shrink, it claims it wont, ive seen many times great performance, but sometimes, well **** just doesnt work out, and it does have a tendency to do so. Also this is very easy to work with dont get me wrong, but be prepared to spend a good amount of time sanding, this is not going to be the easy slap on and your done procedure you saw on pimp my ride.
My suggestion for applying this is to do it in 1/16 or 2/8 inch increments to prevent shrinking one layer on the other, over and over, sand in between and clean thoroughly to prevent air pockets from forming, which is another reason why i suggest not adding it all on at once, air bubbles are damn near inevitable. Another suggestion that would be very helpful to you is get some gloves, and my gloves, im sorry i dont mean Mechanix gloves, theyre too worth wile to be covered in this junk, dont use latex gloves they tear easily, get yourself some grandma's out gardening gloves, theyre the best option youve got because you will get this junk on your hands, it will stick, and it will tear off your skin, its not fun. (mainly if your a smoker like me and you have a smoke without using gloves with bondo, it gets on your lip, and you have to tell everyone that it is not herpes, and explain, thats a real story, that really happened, fml)
Mixing the two are not a difficult task, take a ratio of 3 parts filler 1 part hardener, add as needed i like to make it from being red/gray mix to a semi red mixture, you dont want to apply this stuff without mixing well, it will be gloopy, will become distorted once sanded. I suggest using a 100 grit sandpaper.
SPOT GLAZING PUTTY
This stuff is a blessing and a curse in the same, it can go on practically anything, but best suggestion is just to fix ends/air pockets you missed within using regular body filler. All you need with this is the toothpaste looking tube of putty, and a putty knife.
Use this a small area at a time, piece by piece, when applied all at once and over a large area it tends to crack/not hold well almost immediately, when in small pieces that intertwine it holds much better.
This stuff is a curse because its so fragile, you will need to apply at 1/16th thickness layers, if you go any higher as soon as you start sanding you basically are down to 1/16 all over again if not less almost immediately, its a damn shame. When applying this just take your putty knife and squeeze it onto there, then apply.
Sandpaper preference for this is roughly the 300's, it needs to be something that will not scratch the surface, nor will it tear the putty to shreds, just enough to smooth it out.
Here are some tips that could help you out a little.
- Bondo is available at Advanced Auto Parts, Pep boys, so forth, so on. It is ALSO available at Walmart, which is where i suggest you get yours because its much, much less expensive.
- Bondo comes in increments of 1 gallon and 1 pint, i suggest a gallon as always, because more is better, less and your just screwed afterword.
- When getting a gallon, theres a white cap first off take that off, make sure you have hardener in it (some douches take it out)
- I do not condone nor do i suggest stealing, but while the cap is off because its a rather good area to be covered, it wouldn't be too bad of a call to grab some putty knives or more hardener in order to make your job easier, if your cashier notices, say oops, if not, congrats.
FIBERGLASS RESIN
SPOT GLAZING PUTTY
this should probably be in paint and body, but anyways.
is there a certain amount of time you have to add a layer on to bondo, or will something bad happen if you wait a couple days to do? i work 6 days a week, and am trying to do my bodywork on the side.
at 3am my intelligent self thought i was posting this in the body work/cosmetic info section. Anyways allowing the bondo to dry isnt really a long experience, for example i also work full time and only have one day off a week, that day is when i wake up at 7am to begin work on the car, and end roughly about 1am (too much of a perfectionist for my own good and tweak everything i possibly can plus adding new parts) if you are applying auto body filler, and using the same kind of meathod i do, ide say give it 20 minutes inbetween each thin strip (just enough time to catch up on text messages you have neglected as well as have a nice smoke). Spot glazing on the other hand takes a bit longer depending on the amount of surface area covered.
TylerWestPwnz
May 19, 2010 11:12 PM
