JDM B18C TIMIN BELT
Old May 14, 2010 | 05:06 PM
tweatybird74's Avatar
Default JDM B18C TIMIN BELT
im hoping someone can help me out as I have looked everywhere with no luck.
I have a JDM B18C motor and im wondering if someone can tell me what timing belt im suppose to use on it.
also the JDM B18C has no plug for the crank sensor can someone tell me what i should do in order to get this plugged in so i can reset the code in my computer and shut my engine light off
thanks i appreciate it
Old May 14, 2010 | 05:19 PM
Rdriver's Avatar
Default Re: JDM B18C TIMIN BELT
The usdm timing belt will work fine. You need to order an OBD2 oil pump, which is all Honda sells now.
Old May 14, 2010 | 08:50 PM
forcefedferio's Avatar
In addition to the obd2 USDM oil pump you will also need the oil pump gear with the reluctor wheel, and the obd2 USDM lower timing belt cover.
duh702dc2
Oct 10, 2014 01:59 AM
Bruce_Leroy__
May 1, 2012 10:26 AM
del sol1658
Feb 1, 2011 01:05 PM
roc
Mar 26, 2009 02:28 PM
saer
Oct 15, 2004 08:30 PM
