First radio install and i'm doing it myself!-quick easy question
Old May 14, 2010 | 01:13 PM
nbcivic's Avatar
Default First radio install and i'm doing it myself!-quick easy question
Hey guys, so i know I have to attach the aftermarket harness to the (in this case) pioneer radio harness and plug the aftermarket harness to the stock line.
when i'm matching the wires between the pioneer harness and the aftermarket harness though, do i NEED to solder/crimp or can i just wrap the wires and electric tape. I don't have soldering kit/crimp kit so I would have to buy one if tape isn't sufficient. Let me know.
Old May 14, 2010 | 02:30 PM
94_DC4's Avatar
Default Re: First radio install and i'm doing it myself!-quick easy question
Stay away from the twist and tape method on the radio harness. Sometimes the tape comes undone then you got exposed wires and thats not good. Get a crimper and some connectors and you will be better off.
Old May 14, 2010 | 02:56 PM
b18cKoupe's Avatar
if you really wanna be a cheap *** at least buy some cheap wire nuts, they are far better than just electrical tape. The proper way is to use a crimper and insulated splices.
Old May 14, 2010 | 06:26 PM
fcm's Avatar
fcm
Old Fart
Easy way is to buy a "smart-cable" from Metra, Pioneer plug on one end and your cars radio harness plug on the other, easy, neat and tidy.
Next least expensive is crimp and butt connectors... http://cgi.ebay.ca/271-PC-WIRE-STRIP...item563c0f87cd
Next would be solder and shrink tube...
http://www.amazon.com/Weller-SP23LK-.../dp/B0009ZD2AG 94
Old May 15, 2010 | 08:16 AM
nbcivic's Avatar
so with the smart plug I wouldn't need the aftermarket wiring harness NOR the pioneer harness right?
and I would need a smart cable specific to pioneer and acura correct?
Old May 15, 2010 | 08:19 AM
nbcivic's Avatar
http://cgi.ebay.com/METRA-PR01-80B-P...ht_2632wt_1137 would this work?
Old May 17, 2010 | 06:01 AM
ken9's Avatar
I don't think you can just plug in those in h/u like that.. I don't really trust that plug adapter thing.. I usually would get one at Best Buy and ask associate if not sure. You get what you "pay" for..
Old May 19, 2010 | 04:02 PM
nbcivic's Avatar
yea right now i'm trying crimping, i just have this feeling that it might not be a good connection though? idk
is the point of the crimping to have the wires meet in the middle, or have enough of the copper wire touching the inside so that it relays the signal?
if the latter than i need higher gauge connectors, if not then i need large gauge so i can wrap them around each other inside the connector.
Old May 20, 2010 | 01:36 PM
nbcivic's Avatar
ALRIGHTTTTTTTTTTTTT
wanted to give everyone an update...I'M DONE!
those 2 damn screws and multiple clips drove me insane-but it's done.
working well, I'm just hoping it's all good and doesn't drain my battery ( as in i didn't wire something wrong for the battery to drain).
winne
Audio / Security / Video
Mar 28, 2020 04:34 AM
GuCCi_GSR
Oct 27, 2008 05:09 PM
iENJOIfallen
22
Aug 16, 2008 02:38 PM
Thanks knightsport!
Feb 6, 2006 08:38 AM
93gsrcoupe
May 21, 2005 04:30 PM
