adjusting valve lash - installing gsr cams in b16a2
Old May 14, 2010 | 12:47 PM
azandford's Avatar
Default adjusting valve lash - installing gsr cams in b16a2
I am going to install gsr cams before i retune in my b16 turbo setup. Was wondering if i was going to need to adjust the valve lash and if so how would i go about doing so?
is there a guide to this procedure and is there specific tool i need? im not doing it myself just want to make sure that the person doing the installing is doing it correctly. Got to be careful with sidejob mechanics!
thanks!
Old May 14, 2010 | 08:08 PM
99_EM1's Avatar
Default Re: adjusting valve lash - installing gsr cams in b16a2
installing cams
http://www.c-speedracing.com/howto/caminstall/cam.php
valve lash adjustment
http://www.c-speedracing.com/howto/v...alveadjust.php
Old May 14, 2010 | 09:09 PM
boostedefhatch's Avatar
valve lash adjustments are easy. i did mine last week, tools needed, a feller gauge(not actually a gauge but a tool the has little thin peices of metal rectangles to measure the gap), and 10mm wrench, and a flat head screw driver.
jceltalentoso
Jan 27, 2014 08:54 PM
jceltalentoso
K Series
Jan 27, 2014 06:45 AM
Honda-bond
32
Jan 22, 2011 02:45 PM
Liquid Ice NF
Nov 23, 2005 06:00 PM
