high compression or low compression with a turbo
Old May 13, 2010 | 10:32 PM
93delslow315's Avatar
Default high compression or low compression with a turbo
so im runnin a b16a , me and a friend were talking about compression on my car after i get it turbod. hes telling me to get high compression pistons and that i will have better gas mileage and also run better. from everybody ive heard about turboing cars but him , if your going all motor you stay high compression, if your going low compressions you get a turbo , whos right and whos wrong ? thanks
Old May 13, 2010 | 10:38 PM
jdmh22eg2's Avatar
Default Re: high compression or low compression with a turbo
well u can go high comp turbo but not for long lol
but it really is useally low=boost high=allmotor
and i know someone will chime in and say IT IS ALL IN TUNE and yes that is right to a certain exstent but normally i say lower comp for boost
my build is stock comp because i will be running LARGE turbo on SOHC but 9.0:1 on a sc67 .48 hot side with all forged bottom end FTW end/
Old May 13, 2010 | 10:45 PM
98civdx's Avatar
Master Detailer
I will always say run low comp, but with a proper tune you can do either.
If the boost goes to high with high comp you will need to get into race fuel.
My friend has a 10.5:1 boosted gsr and it runs just fine.
Old May 13, 2010 | 10:55 PM
95DC2GS-R's Avatar
It depends on the condition/strength of your motor and most importantly the fuel you are using..
my b16 is 11.3:1 running on e85 and 30lbs of boost, of course it's sleeved and built
Old May 13, 2010 | 10:57 PM
jdmh22eg2's Avatar
^^ well e85 and sleeves make a HUGE diff lol
what # u make if u dont me asking and on what turbo frame
90teg
Nov 22, 2017 07:02 PM
henchie
Mar 28, 2016 07:20 AM
gustavito1986
11
Dec 8, 2007 08:49 AM
s0liDyNe
Jul 19, 2003 10:24 PM
baonest
May 7, 2002 10:31 PM
