94 ACURA INTEGRA LS W/GSR SWAP PART OUT!!!
Old May 13, 2010 | 03:11 PM
oo9o9xaznoo's Avatar
Default 94 ACURA INTEGRA LS W/GSR SWAP PART OUT!!!
I wanted part out my integra slowly but it seems like its hard to sell the interior and motor swap complete so I decided to part out it out completely. Everything must go! Let me know what you need, Almost all price are negotiable as long as it's a entertaining offer. I had it parked on the street and some 16 year girl stole her parent's car and side swiped my car. Trying to recover as much as I can since I recently dropped over $1,500 doing a valve job and new struts.
Dashboard $100
Center Console(5 Speed) w/ shiftboot $35
Armrest $35
Ashtray & Cig Lighter $15
Climate Control $35
Gauge Cluster $45 (5 Speed LS 86k)
Gauge Cluster Bezel $10
Passenger Airbag $40
Driver Airbag $40
Airbag ECU $40
Steering Wheel $30
Glove Box $35
Hazard Switch $7
Defroster Switch $7
Cruise Control Switch $7
Dash Illuminator Switch $7
Steering Column Cover (2 Pieces) $25
Dash Clock $15
Carpet $75
Driverside Door handle cover/lock $15
Passenger Door handle cover/lock $15
Driverside Door handle(actual handle) $15
Passengerside Door handle(actual handle) $15
Master window switch $35
Passenger window switch $20
Coin Holder $5 each
Door Panels $50 each(can provide package if you want the handles and coin holder)
Front Seats $110(Stitching coming off the driver bolster & one cig burn on the passenger)
Rear Seats $80(upper & lower)
Front & Rear Seat Belts (Does not Include Front Seat Buckles) $100
Headlight/Turn Signal Switch $25
Wiper Switch $25
Sun Visors $30
Sun Roof $100
Headliner $45
Dome Light $10
Map Light $10
Rear View Mirror $10
Front Pillar $20 Each
Door Sill $20 Each
Rear Interior Panel FREE (its pretty beat up in the trunk but the rear seat panels still looks good)(ask for pics if interested)
Rear Trunk Panel(Part that covers the taillight wires)(its pretty scratched up) FREE
Rear Speaker Cover $5 Each
Trunk Carpet $40
Trunk Deck $35
Passenger side floor mat $15(Don’t know what happened to the others)
98+ Driverside Mirror $35
94-97 Passengerside Mirror $15
Trunk Lid $100
Driverside or Passengerside Window $45 each
Passengerside window motor/regulator $75(works Perfect)
Driverside window motor/regulator $75(works Perfect)
Passengerside Door Shell $100
94-97 Taillights $45
94-97 Rear Bumper $50
Passenger side Fender $35
KYB Shocks, Tokico Springs $400 The struts were brand new. Was replaced 1 1/2 months before I got hit. Estimated maybe 2,500 miles on them. Tokico Springs were on the car when I purchased it. Unknown Mileage.
3 Tokico Blues. Missing 1 rear. Unknown Mileage since it was on the car when I bought them but are in excellent condition. Surprisingly compression was still strong when I pulled them out . $125 for 3.
Fat 5 GSR wheels $150 Has Camber wear on the tires, and they're scratched up.
Tanabe Front and Rear Strut Bars $100
UNDERHOOD
I will start parting out under hood parts in the beginning of next month when I have space to pull out the motor & transmission. If you’re interested I have a 96 GSR motor with Transmission 129k. DC Headers, Valve Job w/ all new exhaust valve and intake valve was done less then 10k ago. New Timing Belt, Water Pump, head gasket, Camshaft and Crankshaft Seal, Water Pump, Idler, Tensioner Bearing, Drive Belts. Radiator was replaced new less then 5k ago along with the Radiator Fan Motor. Clutch grabs excellent. No Grinds on any gear.
If you’re interested in the complete swap I will sale it for $2,300.
That will include Complete Engine, Transmission, P/S Pump, Alternator, Axles, ECU, Wire Harness, Shift Linkage.
Engine and Transmission are still inside the car. If you’re interested I can start the car up for you.
I'm also willing to seprate the engine and transmission if someone is interested.
Bare GSR Long Block $1050
Wire harness $100
P72 GSR OBD1 ECU $175
Distributor w/ wires $100
Starter $40
Alternator $40
P/S Pump $35
5 Speed Swap Package
GSR Transmission, Flywheel, bolts, Clutch, Master Cylinder, Slave Cylinder, Shift Linkage, Clutch Lines, 5 Speed Pedal Assembly, Axles, Transmission Mount. Everything you need to convert your car to a 5 speed $1,100. If I get my asking price I will throw in the gauge cluster and the 5 Speed Center Console with it also.
Located in Riverside, CA.
PM me if you have questions or are interested in something that I didn't list up.
If you want a picture of something just request it. I will message you ASAP.
Old May 13, 2010 | 03:34 PM
Peruviann83's Avatar
Default Re: 94 ACURA INTEGRA LS W/GSR SWAP PART OUT!!!
bump and pm'd
Old May 13, 2010 | 04:29 PM
95ProjectEJ1's Avatar
BUMP
Old May 13, 2010 | 05:09 PM
cup cake's Avatar
damn sorry to hear. glws
mendoza84's Avatar
How much for KYB shocks... you have all four?
Old May 13, 2010 | 05:14 PM
JacksonMade's Avatar
How much for the
-door panels
-driver mirror
-and if your giving up the water waste gate?
Might need more things Pm me ill let you know after i get your Pm
Old May 13, 2010 | 05:44 PM
TTT
Old May 13, 2010 | 08:01 PM
PM'd everyone.
Old May 13, 2010 | 08:08 PM
CPT Del sol's Avatar
glws
Old May 13, 2010 | 09:23 PM
KINGVEM^^ED6's Avatar
Tooo spensive for me
Old May 13, 2010 | 09:26 PM
lol
Bump
Old May 14, 2010 | 04:54 PM
albanzek3's Avatar
can get some pics of the fat fives
Old May 15, 2010 | 01:12 AM
Cheeech's Avatar
Let me know if you sell the header, thanks
Old May 15, 2010 | 01:56 AM
ttt
Old May 16, 2010 | 07:04 PM
Anon51's Avatar
how much for the throttle cable shipped to 11355
Old May 16, 2010 | 07:12 PM
Mashi2Choco's Avatar
how much for the passenger side door? no need for anything else except the shell i guess.
Old May 18, 2010 | 03:29 PM
Remhk714's Avatar
would u consider for selling the motor and installing it?
Old May 18, 2010 | 08:14 PM
Gee745's Avatar
how much you want for the rear hatch with the glass and the side skirt. tex with a good price and i will pick it up this weekend. 562-394-6960
Old May 18, 2010 | 08:54 PM
cup cake's Avatar
knock sensor?
Old May 24, 2010 | 09:42 AM
ttt
Old Aug 9, 2010 | 12:59 PM
DeucesWild's Avatar
pm'd and bumped..
Old Aug 9, 2010 | 04:27 PM
Black-Ty [EG6]'s Avatar
damn 1k for 5spd conversion?? crazy!
Old Aug 10, 2010 | 03:12 PM
DA_PoWeR's Avatar
still have the p72 ecu?
nightscream
Mid-Atlantic (Sales)
10
Jun 8, 2011 12:58 PM
Spoon84
Sep 8, 2010 06:23 PM
iM x Omar
Aug 6, 2010 02:13 AM
HARI.
Nov 27, 2006 06:29 AM
