bumper removal
Old May 13, 2010 | 11:27 AM
clowery89's Avatar
Default bumper removal
does anyone know a link or step by step how to ge the bumper off mine is all messed up and i wanna fix it
Old May 13, 2010 | 11:43 AM
HonBeer's Avatar
Default Re: bumper removal
bumper cover or the bumber itself?
Old May 13, 2010 | 11:56 AM
ilikehonda's Avatar
grill, headlights, bumper lights, fender bolts, plastic push pins on top of cover....off
Old May 16, 2010 | 06:12 PM
sgraham01's Avatar
if you have a 96 accord, you will need to remove the screws at the rear corners, bolts and clips underneath the car, sidemarker lamps, bumper lamps, and the grille. Now remove the push clips along the top and behind the sidemarkers. If the bumper has never been removed and the retainers that hold it to the rebar are still installed under the headlights, you will need to remove the 4 12mm bolts behind the bumper lamps (extension and socket through the light pockets) and take the rebar off with the cover since there is no way to get the clips off that are under the headlights and you can't take the headlights out without taking off the bumper. you can just reinstall the rebar by itself, then add the cover to it and leave off the push clips that were under the headlights.
deeweezy187
Aug 12, 2007 12:54 AM
racerxfactor
Mar 12, 2007 05:08 AM
jjokerzwild
Jul 22, 2006 01:26 PM
StreetGlwLude
Sep 20, 2004 04:49 PM
Jurassic Four
13
Jun 4, 2004 03:14 PM
