power locks won't unlock
Old May 13, 2010 | 09:24 AM
ynk1121's Avatar
Default power locks won't unlock
I'm trying to fix my sisters 2 door 96 Accord and am hoping you guys can help me out. The power locks won't unlock either door from either door switch. It locks fine. The actuator appears to be ok because when you lock it with the door open it moves to unlock. I'm 100% sure the switches are fine. I checked it with a continuity meter and it works. I was also able to ground the lock wire to make it lock, but after grounding the unlock wire it still won't unlock. I have a cheap manual but it's not that helpful. It appears the switches are wire to a "multiplex unit". It makes no mention of where it is or the pin out.
on the wagon
Apr 4, 2022 02:46 PM
Andrewm224
Oct 21, 2005 07:33 PM
Sanj
Oct 2, 2005 08:22 AM
Back in Black
Jul 7, 2002 12:27 PM
