'99 EX 4 cyl sedan inner tie-rod replacment
Went for New Hampshire inspection. Tech said pass side inner tie rod JUST made it under the tolerance play. Needs replacing. Just did all wheel beating and the outer tie rods with Moog greeseable problem solvers. How hard is it to replace the inner, do I need to replace the steering rack boot at the same time?
you don't have to replace the boots, but unless they look as good as new you may as well since you'll have to remove them to install the joint, and they don't cost too much.
it's been a while since i've done one on an accord but IIRC you can do it without removing the rack. it can be a pain though.
Well my independant Honda guy wants $240 to do both inners! I have a lift in CT should I just take it down there to do it,myself are they a rea PITA!
RichieHHix62
Feb 5, 2018 12:55 PM
VersedCivic
Jul 12, 2014 10:50 AM
rhd98civic
May 20, 2013 03:27 PM
shortlid
Apr 4, 2007 10:28 AM
