ls/vtec help with gsr pistons on ls rods
Old May 13, 2010 | 05:51 AM
sleepencivic's Avatar
Default ls/vtec help with gsr pistons on ls rods
oem gsr pistons on oem ls rods is machining required to get them to fit? i thought all b series pistons would fit.... but i do remember now that some dont... I know the b16a pistons fit without machining the small end.
Old May 13, 2010 | 07:41 AM
TheCrimsonGhost666's Avatar
Default Re: ls/vtec help with gsr pistons on ls rods
Just a suggestion, but you should look into some other pistons, gsr pistons arent going to raise your compression much, which im assuming is what your trying to do. Look into some p30's, pr3's or p73's. RS machine has pr3 replicas for $150 with rings on ebay if your on a budget. I know p30's fit without machining and p73's DO need machining, dont know about pr3's.
Old May 13, 2010 | 07:47 AM
ruffrhyder's Avatar
GSR and ITR pistons will need machining, all B16 pistons will clear LS rods.
Old May 13, 2010 | 08:50 AM
hondamn1320's Avatar
You need to machine 1mm off the small end in order to fit the GSR/ITR pistons.
young geezer
Oct 15, 2010 05:13 PM
BMo Tuning
Dec 7, 2008 05:06 PM
danthemang3
Jun 3, 2005 05:57 PM
B2FiNiTY
Aug 27, 2003 09:48 AM
TurBoTeG
Dec 10, 2001 08:54 AM
