*noob question* re: fitting '04 STI rims onto RSX
Old May 12, 2010 | 09:36 PM
DaTruth1's Avatar
Default *noob question* re: fitting '04 STI rims onto RSX
I have rims from an '04 STI rims, the bolt pattern is 5x100. RSX fits 5x114.3. What type of adapter will I need? Is it 5x100 to 5x114.3, or is it 5x114.3 to 5x100? Also, is it safe to use these rims with an adapter? Any dangers?
Old May 13, 2010 | 03:21 PM
95lscivic's Avatar
Default Re: *noob question* re: fitting '04 STI rims onto RSX
You would need a 5x114.3 to 5x100 adapter.
Old May 17, 2010 | 01:06 PM
r.wright's Avatar
and keep in mind the suburu's wheels are 56.1 center bore so if you want to go lug and hub centric the opening of the spacer needs to be 64.1 mm and the part that goes into the rims needs to be 56.1 mm
RICKYritethere
May 9, 2007 01:47 PM
picos
Sep 10, 2006 12:23 PM
01-0720
Acura TSX
Jan 25, 2005 02:15 PM
IgotV-tec!
Jul 21, 2003 12:22 PM
1Tym
Feb 1, 2003 12:52 PM
