gauge wire issue
Old May 12, 2010 | 08:19 PM
burnykawizzle's Avatar
Default gauge wire issue
i bought a air fuel gauge but i dont have a o2 sensor on the exhaust. i also bought a oil pressure and a water temp gauge thing is HOW DO I INSTALL IT???? i have a 95 acura integra non vtec LS
Old May 13, 2010 | 12:12 PM
wtf_is_jdm's Avatar
Default Re: gauge wire issue
You don't have an O2 sensor? And if you don't, then why? And as for the Oil pressure, you will need to get a oil filter sandwich plate. You can find them anywhere from ebay to golden eagle. It is a simple little system. But if you do it, do it thoroughly, and make sure it is all nice and tight. (but not too tight under there) And as for the Water temp gauge..... you could t off one of your coolant lines, or use the water neck. your choice. Good luck
Old May 13, 2010 | 02:18 PM
mouab18c1's Avatar
Its pointless to have an AFR gauge without a 5v 02 sensor.
Old May 13, 2010 | 03:15 PM
^^^^^ i know i have tried to order some from ebay but i dont know which one is the one i need to order.... my headers dont have a o2 sensor but my cat converter has the bung for the o2 sensor thing is which one do i get??? help would be great
Old May 13, 2010 | 03:16 PM
oh btw what is a water neck and where could i find it??
Old May 13, 2010 | 07:43 PM
wtf_is_jdm's Avatar
You might as well get the money together for an AEM wideband.....it comes with an O2 sensor and has capability for data logging. and your waterneck is right where your thermostat is.
Old May 19, 2010 | 11:31 PM
i have the gauge already so i might as well get it installed. thing is can i get a wire tap from the ecu plug and have the gauge work like that or do i need a o2 sensor?
Old May 20, 2010 | 06:39 AM
213374U's Avatar
0x5359-0055
Community Builder
From the sounds of it, you have no idea what you are doing. Given that, I'm also going to assume that even if they did give out a proper reading, you wouldn't even know what you're looking at. My opinion, just hook em up to battery power so they light up and everyone thinks your car is quick
Old May 20, 2010 | 06:54 PM
lol im not trying to make it look like it goes fast. im just trying to do the wiring the proper way and yes i dont really know what i am doing that is why i am asking...
DCSportEJ1Civic
Aug 2, 2007 12:54 PM
hondaguyexsi
Oct 8, 2005 06:58 PM
dimes_prelude
Jun 7, 2005 05:19 PM
photonjedi808
25
Apr 17, 2003 12:08 AM
