1996 Honda Fuse.....Question Help! (Taillights Work, Brake Lights Don't)
Old May 12, 2010 | 06:01 PM
BAYAREAYO's Avatar
Default 1996 Honda Fuse.....Question Help! (Taillights Work, Brake Lights Don't)
I tried replacing the bulbs didn't work
also my taillights work but my left and right brake lights don't
and not to forget that my center rear light IS working.
With that being said I can only hope that my fuse is blown for now
MY QUESTION TO YOU IS
WHERE IS THE FUSE THAT I NEED TO CHECK?
http://picasaweb.google.com/lh/photo...eat=directlink
PLEASE TYPE IT OUT OR
GO TO PAINT AND CIRCLE IT OR SOMETHING.
IM A CAR NEW BUT LOVE MY HONDA
all help is appreciated!
PeacE!
Old May 12, 2010 | 06:19 PM
silent1jt's Avatar
Default Re: 1996 Honda Fuse.....Question Help! (Taillights Work, Brake Lights Don't)
i had that happen to me before...i believe that is the dimmer switch fuse under the hood. or small light (cant remember for sure) its one of those two
Old May 12, 2010 | 07:37 PM
bseriescrxsi's Avatar
small light wo9uld be if tails didnt work n brakes did.....could be the resistor units on each side though both at the same time is a little odd
Old May 13, 2010 | 05:05 PM
hb_guy's Avatar
check the horn fuse. horn and brake lights are on same circuit. but if your horn works it is not your fuse(chck it anyways). good luck
Old May 13, 2010 | 05:16 PM
TheMuffinMan's Avatar
He knows where you live!
Those are dual filament bulbs, did you replace the bulbs with the correct ones? If you just have a single filament it won't work.
And for fuses, all you have to do is pull them and look at them. The time you spent making the thread you could have already gone through the under hood box.
b18c1vtecdc2
Sep 2, 2013 09:31 PM
JAYDmManny1331
Sep 16, 2009 10:43 PM
dankies
Feb 8, 2006 08:32 PM
Fraggle
Feb 15, 2004 06:14 PM
Jdmglenn
Oct 14, 2003 07:03 PM
