Poped EP3 Motor... what else is a drop on option?
Old May 12, 2010 | 04:45 PM
bart simpson's Avatar
Default Poped EP3 Motor... what else is a drop on option?
looking for a direct plug in(i have the poped motor in the car so i can pull all the sensors ect out..)
looking for a bolt in plug in setup... if the k20a3 is the one for that job.. so be it.. i just think the car could use the torque of a 2.4L vs2.0------------------please keep the "put the k20 head on bs to yourself" its a 100% stock civic just needs a motor asap
-im thinking a crv motor???? though the k20a3 engine is cheap i dont have any locally.
Old May 12, 2010 | 06:06 PM
blackKready's Avatar
Default Re: Poped EP3 Motor... what else is a drop on option?
what is in it and a type s engine is the only drop in simple options.
Old May 12, 2010 | 06:58 PM
lostniraq25's Avatar
i picked up a K24A4 for 1000 shipped from a seller in Florida, and its a farely simple swap. CRV passenger motor mount, 310cc injectors, and a Hasport I/M adapter. If you have kpro you can run with the stock injectors.
Old May 13, 2010 | 12:04 AM
josh's ep3's Avatar
Function > Form
I've heard you can even run a bone stock a4/a1 with the stock ECU, could be wrong though. Anyone care to chime in on that??
Old May 13, 2010 | 04:34 AM
mustclime's Avatar
k24a1,a4,a8.....will all run on the stock ecu. The a4/a8 are both accord motors and they can be had for less than a grand....you will need a couple things........
An crv motor mount(pasneger side) and some 310cc injectors from a type-s or tsx.....you will want to swap all the pulleys,ac compressor,water pump and tb.....depending on what motor you get, you will need the intake manifold...or not....there is a pia water passage at the rear of the head that is a little different on each motor....
Also....the k24's are 19mm taller than the k20's....this means the head is higher, as a result any header/ header/cat combl you use will be pulled up higher, A lot of people have problems with them hitting the front sway. There are a couple fixes for this....1) 2003 em2 coupe ft sway, its smaller and hugs the tunnel....2) edm ep3 type-r front sway....you can get them from jdm land, they have a different bend that makes more room for the header.....or 3) run no front sway.
Hope that helps.
Old May 13, 2010 | 08:56 AM
Hope that helps.
x2 what musty said. im running no front sway right now and dont do spirited driving so its not much of a problem, but plan on buying a front sway in the near future
Old May 13, 2010 | 11:20 AM
bradfindley's Avatar
I have a K20a2 and all the parts from a '03 RSX Type-S. You could drop that right in! $3,000. Check out the pics here:
https://honda-tech.com/forums/showpo...8&postcount=40
Old May 13, 2010 | 06:17 PM
a. not my car
b. kids not spending $3,000 on a $5,000 car...
cars is 100% stock 2002 civic si.
Old May 13, 2010 | 07:16 PM
Igaly's Avatar
well it depends what you want it for if you use your SI for regular driving then drop in another k20a3 but if you want it for racing drop in a k20a2
Old May 13, 2010 | 07:28 PM
Originally Posted by bart simpson
a. not my car
well what are the price parameters?
Old May 14, 2010 | 02:52 AM
the kids not racing... its 100% stock car!... does a k24 out of a crv work.... thats pretty much my only question... hes got all parts from a 2002 si... nothing more.. hes not going to buy injectors or a k pro. hes not going to spend the $ on the a2... he probably wont even go for the $1000 junk yard motor (if found)
Old May 14, 2010 | 04:20 AM
Igaly's Avatar
yea a K24 fits but your gonna need the CR-V bracket. but other than that its a direct swap
Old May 14, 2010 | 02:45 PM
alex_rsx's Avatar
id go with a crv k24, added torque and just about the easiest k24 swap. cant go wrong with that.
Old May 17, 2010 | 11:15 AM
AddictsRacing's Avatar
Then what is the point of this post? If you know he isn't going to buy anything but the stock factory motor, then there really is no point in taking into consideration if the K24 fits or not.
As stated previously, the K24 WILL fit, it just needs some different parts that the factory K20a3 motor does not utilize. Such as, the CRV mount, 310cc injectors, and Kpro. These are not meant for you to "race." We're just stating this is what you WILL need to make the motor work in the EP3 civic.
Old May 17, 2010 | 11:43 AM
SkoundrelUSA's Avatar
cute little bastard
If your friend is a nit picky bozo, tell him to stop whining and just get another K20A3
Old May 17, 2010 | 01:10 PM
a. not my car
I'll give him $2,000 for the car as is. The price I quoted would get you all in. All of the other options above don't include the $1000's of other parts just to make it work.
MONSTERek4
Sep 8, 2008 05:41 PM
HondAcura
Jun 24, 2006 06:19 PM
busychild
Nov 20, 2003 05:13 AM
