intake manifold ??
Old May 12, 2010 | 04:32 PM
bradennicely's Avatar
Icon2 intake manifold ??
can you put a skunk2 b18c intake mani on a b18b? i have one laying around with a elderbrock throttle bottle and what to put it to use.
the part numbers are different but has anyone done this before?
Old May 12, 2010 | 06:37 PM
Default Re: intake manifold ??
anyone?
Old May 12, 2010 | 11:36 PM
seanbev24's Avatar
No, different bolt pattern.
Old May 13, 2010 | 12:06 PM
sure? ive seen ppl but b18b mf on b18c before
not sure what all was done to make it fit though
Old May 13, 2010 | 12:16 PM
wtf_is_jdm's Avatar
not worth it. ^like he said, a different bolt pattern and if I am not mistaken, b18c i.m. also has more of a clam shell shape. I may be wrong btw
Old May 13, 2010 | 02:36 PM
seanbev24's Avatar
OK I'll rephrase... It is possible, but only with custom fabrication. Not worth the trouble IMO.
Old May 13, 2010 | 03:24 PM
wunfstgsr's Avatar
Loved
Community Favorite
you can try putting a ls gasket to the gsr manifold and see how close the ports match and redrill the holes for the studs and also you can port it with a dremel if it needs a litle shaving depending on how close the port shapes are. also make sure the coolant pass. matches if not you might need to retap that as well. but it can be done.
JDM_Spec
Oct 4, 2023 08:09 PM
twistedimage
Apr 7, 2022 05:44 AM
710dabber
Jun 23, 2015 07:50 AM
Simkin314
Oct 8, 2009 09:21 AM
cslegacy
Mar 9, 2009 11:58 PM
