What happen if you forgot to put a washer on the transmission drain plug?
Old May 12, 2010 | 03:33 PM
Bad_dude's Avatar
Icon2 What happen if you forgot to put a washer on the transmission drain plug?
I have a 1990 LX, 4AT Honda Accord. I just changed out the transmission fluid today with the new Honda Premium ATF, $8.50/qt. I even bought a new silver washer for it, $1.98 each. When I took the drain plug off, I discarded the old washer and clean the shaving off from the drain plug. I then put the drain plug back on FORGETTING to put the new washer on. I torque it at 36ft/lbs. I already fill the new fluid in there about 2.5QT total.
I plan on changing the fluid again on the next oil change which is about another 2800 miles. Would it start leaking without the washer in there? Would it hurt anything without the washer in it?
I was thinking I would change it out again soon, so without the washer it would not leak. Should I just drain out the fluid and put the washer on OR just wait the 2800 miles then put on the washer then.
It's a bad mistake, but it happens.
Thanks.
Old May 12, 2010 | 05:17 PM
sony224422's Avatar
Default Re: What happen if you forgot to put a washer on the transmission drain plug?
drive it a couple miles.. do a short little loop around and come back to your house and see if its leaking.. if not i wouldn't stress about it.. just keep an eye out. if its leaking well then fix it.
Old May 12, 2010 | 06:07 PM
Bad_dude's Avatar
It's not leaking. I was just going to drive it until the next oil change and put the washer on with new fluid at that time. I don't have a clean container otherwise I would drain and put the washer on. Maybe I can use my finger tomorrow and put the washer on without losing too much fluid.
I just wonder if any one ever forgot to put the washer on and what is/was their story?
Old May 12, 2010 | 06:48 PM
ricebike's Avatar
make it right and put that washer on it
or
just check your trans fluid level EVERY DAY
Old May 12, 2010 | 07:39 PM
Bad_dude's Avatar
Icon3 Re: What happen if you forgot to put a washer on the transmission drain plug?
or
Every day is a bit too time consuming. I think I am just going to drive it a little bit then drain again to put new fluid in then.
Thanks,
Old May 13, 2010 | 10:50 AM
Bad_dude's Avatar
I did it. Jack it up, loosen the bolt. Since the car was cold the fluid did not come out too much. Put the wash on and drain plug back on with a washer this time. Feel better now.
Took it for a drive on the freeway and I don't even feel it shifting into gears at all. Also, I notice my bogging down at 45MPH into 4th gear seems to be gone too.
I wonder if the EGR even need service with the car only at 140K miles. I did try to take the bolts off the EGR valve again, it finally turn BUT b/c the freaking socket cracked. So much for that.
Old May 13, 2010 | 04:19 PM
Conflicted's Avatar
The EGR at 140k needs to be cleaned if its giving you any sort of issues as gunk can build up in it.
Old May 13, 2010 | 04:26 PM
sony224422's Avatar
.. did you fill it back up?
Old May 13, 2010 | 04:51 PM
Bad_dude's Avatar
Yeah. I filled it back up.
Moosa S
Honda Civic (2006 - 2015)
Nov 13, 2018 03:19 PM
wwj22000@yahoo.
Apr 11, 2012 04:12 PM
blouthan
Transmission & Drivetrain
Mar 6, 2009 05:01 PM
SpazMan
Apr 29, 2008 09:41 AM
vics_si
Aug 4, 2005 04:47 PM
