sunroof wont open
i have a 95 Si. when i push the button it makes a clicking sound but doesnt open the sunroof. i have checked fuses 16 and 19 under the dash and they are both good
had the same problem. what i did was change the relay for the sunroof. its this 2 little grey thing that powered the sunroof. mine is a em1 so it might be lil diff. give that a try!!! it suck not to have the sunroof not working.
I know this is an obvious question.. but have u tried jus givin it a lil push? Mine was doin the same thing, and after tryna go thru wires, it was jus in need of a lil pushing assistance haha
i tried to give it a little push and that did not work. also, my intermittent wiper is not working. my other wiper speeds work. could these 2 be related to the same problem?
^ he means the relay for just the sunroof
check www.hondahookup.com they have many full manuals for download via PDF file should tell u were to find a relay
Same thing happened to me, but part of my wind deflector arm had broken off and gotten trapped. I eventually just messed with it till it gone so far back it didn't interfere with the operation of the sunroof anymore.
More than likely relay. Been there with the same problem, relay would click over put wouldn't send current to the motor. Only difference is that mine wouldn't close (real fun, right)? Try tapping the relay a bit with your hand or a screwdriver, see if it frees up, could check the terminals on it as well. If anything, just replace it.
i bought a 95 eg hatch a few months ago. sun roof didnt work and after reading this then trying the "push" method it worked. thanks for the help fellas! now onto the clutch and rear main seal replacement.
hey anyone know how to maintain the sunroof? i have a eh3 and my sun roof works but gets stuck when closing have to pull it closed while pushing the button. i would really like to get it to open and close properly. please help. what grease.... how to clean. you know general maintnance.
