No 02 sensor wire on engine harness, 91 civic si
Old May 12, 2010 | 09:51 AM
soledadcivicstd's Avatar
Default No 02 sensor wire on engine harness, 91 civic si
Alright, I got a new harness and realized there is no wire for the o2 sensor. I was wondering if I can just wire an o2 sensor straight to the ecu and how I would do that.
I know that on the ecu the pin is C36. do i just run a wire straight to that?
Old May 12, 2010 | 09:54 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: No 02 sensor wire on engine harness, 91 civic si
That would be one way of doing it. If possible use an appropriate pin to insert into the ECU plug.
Old May 12, 2010 | 10:22 AM
lunalink's Avatar
yes. you can do that.
just grab an extra wire/pin from the junkyard and solder/heat shrink the extra wire/pin onto your 02 and call it a day
Old May 12, 2010 | 10:51 AM
jxh_28's Avatar
or u can chip an ecu - o2 sensor disabled.
Old May 12, 2010 | 01:38 PM
niiiiice. imma do that today after work then
Da_1991
Nov 10, 2013 07:14 PM
kevinoneill
Dec 25, 2010 01:05 PM
1sikhatch
27
Feb 10, 2006 07:43 AM
Frankinfreak300
Sep 27, 2003 08:43 AM
civicmatt
Jun 22, 2003 07:27 PM
