Honda crx wheel bore diameter enkei rpf1
Old May 12, 2010 | 09:06 AM
acmoc's Avatar
Default Honda crx wheel bore diameter enkei rpf1
Hi,
I finally figured out what size wheel I need for my 1991 honda crx
It's lowered 3 inches. I'm going with the 15x7 +41
But the guy I'm going to buy it from says I need an adapter ring for the bore.
The ekeis bore is 73. He says the crx needs a 64.1.
Do I really need this? It's 40 more dollars?
Thanks
Old May 12, 2010 | 12:14 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Honda crx wheel bore diameter enkei rpf1
Yes, you need it, but the CRX needs a 56.1, not a 64.1.
The reason you need it is that, if you don't get adapter rings, the wheels will be relying solely on the lug nuts for centering, not the hub. Some people luck out, but a lot of others have problems with wheel/tire vibrations without the hub centering rings.
Old May 13, 2010 | 09:03 AM
acmoc's Avatar
Cool, thanks for the sharp answer =]
Is it okay that they're polycorbonate
03K20A3Si
Classic Hondas
Aug 12, 2011 02:31 PM
ham
Nov 22, 2005 03:42 PM
Hondasaurs
Nov 6, 2001 09:58 AM
