Shock tower pin outs for the 93 OBD1, SOHC, non-Vtec, D15
Old May 12, 2010 | 09:01 AM
Acidcrakker's Avatar
Default Shock tower pin outs for the 93 OBD1, SOHC, non-Vtec, D15
After Carefully taking apart a del sol harness I made notes on what is what and what goes where.
The image in the post below me, is nothing more than a crappy diagram with out having anything labeled and its also missing a whole plug off the wire harness itself. So it is incomplete IMO.
Here is mine. I did this one for a Del Sol wired up for the H22a motor.
Old May 12, 2010 | 04:58 PM
Markb16a's Avatar
Default Re: Shock tower pin outs for the 93 OBD1, SOHC, non-Vtec, D15
BAM!! I found something for you
look at this.
http://img682.imageshack.us/i/shockt...ugpinouts.png/
Old May 12, 2010 | 06:21 PM
nice job.
One more question if you may.
Im doing a wire harness for a guy. But he sent me a wire harness that has the shock tower plugs cut off. Mhew. But here is the thing. It looks as if the harness connects on 2 sides of the firewall.
Ive delt with Preludes and Civics before, and so far I have seen nothing but shock tower connectors all on the passenger side of the car. Nothing on both sides. Is this normal for del sols?
Old May 17, 2010 | 05:55 AM
What helms manual can I use for this car for the 93 wiring? Is it the same as the 93 civic?
Im looking online and dont see anything related to the OBD1 del sols here. So Im thinking that I can use a civic manual?
Old May 17, 2010 | 01:35 PM
94EG8's Avatar
Seagull Management
'92 - '95 Civics, '93 - '97 Del Sols and '94 - '01 Integras all share more or less the same engine harness design, they have plugs on both the driver's and passenger's side shock towers.
Old May 17, 2010 | 08:42 PM
Thanks. That clears up alot
Old May 28, 2010 | 06:34 AM
look at this.
Actually Im looking at this and comparing it to the harness I have and this one does not match up to what I have.
This connector only has 3 plugs to it, the actually harness has 4 plugs.
Even at that, im comparing the plugs to the wires I have and the colors dont match up either. I dont think that diagram is for the p06 non vtec del sol.
Old Jul 13, 2010 | 06:28 AM
BUmp for first post updated
SpoonCivicSir20
Oct 23, 2019 09:42 AM
Benito89
13
May 2, 2011 11:41 AM
Del Namco Solo
Audio / Security / Video
Apr 7, 2010 02:13 PM
Qfactor
Mar 1, 2004 09:11 PM
