92da front end doesnt lower??
Old May 12, 2010 | 02:39 AM
JdM_Eg6_SiiR's Avatar
Default 92da front end doesnt lower??
what up guys. i got a 92 integra, ive gone threw three sets of suspension and no matter how low i drop it the front passenger side barely lowers like an inch. the front driver side and the rear is all slammed but the front passenger side sits all high. i dont know what to do.
Thanks.
Old May 12, 2010 | 06:15 AM
MD426's Avatar
Default Re: 92da front end doesnt lower??
What suspensions did you use? If you are using a coil over sleeve you may have the sleeve upside down on the strut.
Old May 12, 2010 | 11:07 AM
the first set was just some tokiko shocks with skunk2 coilovers, then i got got some tein basics, and right now i have the buddyclub n+ spec.
Old May 12, 2010 | 11:19 AM
MD426's Avatar
Are the control arms bent or seized up? Something is preventing full suspension travel if you have a full coil over setup and it's not dropping.
Old May 12, 2010 | 07:16 PM
how do i check if the control arm is seized up?
Old May 12, 2010 | 08:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Remove coilover on that corner of the car, disconnect sway bar, and then push up on the suspension. Take it all the way up until the upper control arm touches the shock tower. That will verify that you have the full suspension travel available.
Old May 13, 2010 | 05:11 PM
ok, i did what you said and the upper control arm does touch the shock tower.
Old May 13, 2010 | 05:42 PM
danthemang3's Avatar
try loosening the lower control arm bolts, with everything installed then lower the car. if its all good then tighten them up with the suspension compressed.
alec1241
Apr 2, 2016 02:12 PM
TurboGS-R
Suspension & Brakes
Apr 17, 2006 01:50 PM
Cabby89
Jan 31, 2005 03:20 PM
wreckedmyteg
Oct 31, 2004 08:17 PM
Gennady
Sep 25, 2002 03:49 PM
