wiring door actuators for alarm into 92+ civics?
Old Sep 11, 2002 | 08:14 PM
rsx03's Avatar
Default wiring door actuators for alarm into 92+ civics?
which wire is what on these actuators? how do you hook them up and make them work simultaneosly when alarm is ARMED ?
did anyone of you install these yourself and how hard was it to do?
thanks!
Old Sep 13, 2002 | 06:10 AM
rsx03's Avatar
Default Re: wiring door actuators for alarm into 92+ civics? (2K1GSRBOY)
anyone??
Old Dec 30, 2002 | 05:41 PM
Fuster_Cluck's Avatar
Default Free bump!
I need to see about doing this for my 93 Cx. I'm tired of using the key to enter my car. I can care less about once in the car since I lock it manually, but the entering with a key has to GO!
Anyone?
How much are actuators?
Old Dec 30, 2002 | 07:16 PM
Desslok's Avatar
Default Re: Free bump! (Hybrid93Hatch)
What I usually do on these is mount the actuator and run the wires into the car. Leave the door panel off for any adjustments. Run the wires to where you are going to hook them up to the relays, wire up the relays. Then with my makita battery I touch the wires to the battery both ways alternating back and forth to make sure it locks and unlocks several times, adjust if necessary. Then whatever way on the battery made it lock, the + goes to the armed/lock relay. Other wire - goes to disarmed/unlock relay.
Old Jan 1, 2003 | 08:05 PM
95CoupinIt's Avatar
Default Re: Free bump! (sp)
couldnt have said it better myself... except i use my craftsman drill battery...lol
fatfurious2
Aug 26, 2007 08:34 AM
konidude
Audio / Security / Video
Oct 17, 2006 09:11 AM
Maverik4k
Sep 21, 2004 09:36 PM
ketchup_gsr
Oct 29, 2002 08:05 AM
ketchup_gsr
Oct 28, 2002 08:55 PM
