ECU PINS???
Where can i get ecu pins that plug into an ecu so i can wire my vtec to my ecu.
i'm not sure if i'm lookin for the pins or the ecu wires. not sure what to call them
i just need the things that plug into my ecu to wire my vtec,
please help.
please help.
Any Honda OBD1 connector will work. There are two different sized terminals. The drivers or ouputs are larger (VTEC solenoid). The inputs are smaller (VTEC oil pressure switch). Once you examine the connector, youll see what I mean. You can actually pull the terminal out of the connector and snap it into your ECU connector. Youll have plenty of extras to practice!
CivicxTree754
Apr 27, 2011 11:51 AM
