GSR & LS valves,crank pulley,t-belt the same or not?
Old May 11, 2010 | 02:10 PM
smokey.23's Avatar
Default GSR & LS valves,crank pulley,t-belt the same or not?
does anybody know if gsr valves,crank pulley,timing belt,water pump will fit LS ?
Old May 11, 2010 | 03:37 PM
robfrmny21's Avatar
Default Re: GSR & LS VALVES,CRANK PULLEY,T-BELT THE SAME OR NOT?
your in a the wrong section, the gsr valves and water pump are diff from ls and can not be used on a ls block with ls head combo, you can use above with ls block and gsr or b16 head.
the pully can be used on ls
alvarez.esteban
Aug 27, 2016 12:00 PM
uuuuuuuuuuuu
Mar 12, 2007 02:46 PM
ProPanda
Dec 13, 2005 05:44 PM
drdavidge
Jun 3, 2002 01:54 PM
