my fog lights are not working. can someone figure out why?
Old Sep 11, 2002 | 07:39 PM
GSblueRacing's Avatar
Default my fog lights are not working. can someone figure out why?
It's an aftermarket fog lights and I connected it the conventional way the instruction says, not hooking up to the high/low beam, It has it's own switch.
I was using it tonight, It was fine until I parked and turned them off.
an hour later when I about to head home, I flipped the switch and this is what I got::
THIS IS how the switches was designed. RIGHT side has a Green light, LEFT side has a RED light.
(If the switch is off, on the right side of the switch, it's a GREEN light, If the switch is turned on, the GREEN light would go off and the RED light on the left side would lid up)
BOth lights didn't come one. I tried it a few times and pushed the switch on /off. Everytime I pressed it to ON, I would see the Switch try to turn on because the RED light would lid up and then went off, but neither fog lights were on. When I turned it OFF, the GREEN light is on and is normal. and when I tried to turn it on again, I see the RED light tried to turn on but nothing happened and I heard "zaaap, zaaap, zaaap"(eletricity sound) and the RED light would bling at the same time too.
SO where is the faulty spot? my connection has a 12V relay and alos a little fuse box(15A.)
Old Sep 12, 2002 | 12:32 AM
integrx's Avatar
New User
Default Re: my fog lights are not working. can someone figure out why? (GSblueRacing)
check for lose ground or power wire. maybe fuse is off. bulbs broke. you'll figure it out!
Old Sep 12, 2002 | 09:15 AM
Default Re: my fog lights are not working. can someone figure out why? (integrx)
I don't think 2 bulbs are broken. the switch has power going into it, it's jus that when i turned it on, it's like it's trying to turn on becasue i see the RED light going on then off, but no go.
mvp40
Jan 23, 2012 07:38 PM
hondaboy4life
Feb 2, 2006 08:12 PM
al_r
Oct 18, 2003 07:28 AM
GSblueRacing
Sep 12, 2002 09:28 AM
GSblueRacing
Sep 11, 2002 07:57 PM
