what pistons are you guys using?
Old May 11, 2010 | 08:18 AM
young geezer's Avatar
Default what pistons are you guys using?
well i am getting board with my stock internals and want to change few things. it was tunes about a year ago and pulled 175 whp with v tec controler. now i wanna pull little closer to 195whp. i dont wanna go all big and fully built it. i was thinking more like a new higher compression pistons like CTRs. i dont really know what else to change since i like everything aobut the type r motor. what would you guys recommend changing for little more power in my engine. i was even thinking nos with like 50 shot too. but the car is a daily drive and i wouldnt be shooting nos all the time. i need something strong all motor.
Old May 11, 2010 | 09:36 AM
92TypeR's Avatar
FSAE
Default Re: what pistons are you guys using?
I am running 12:1 CP's in my 2.0L...
20,000+ miles so far so good.
Old May 11, 2010 | 09:52 AM
redGSRguy's Avatar
I went with o/s jdm itr pistons. If I could go back in time I would have just got some aftermarket pistons...
Old May 11, 2010 | 09:53 AM
REDTMNT's Avatar
How about some new more aggressive cams?
Old May 11, 2010 | 11:15 AM
ya i was thinking about cams too but i just keep hearing from people that type r cams are really good.
Old May 11, 2010 | 11:16 AM
are you using ls crank to make it 2.0L? how much power are you pulling on your motor?
Old May 11, 2010 | 11:22 AM
Todd00's Avatar
I said I don't want a title!
Is this for a Type R or do you have an ITR motor in another car? One will affect the value (if original), the other should probably be asked in the all-motor forum.
Old May 11, 2010 | 11:39 AM
it ITR motor in another car. i asked here because everone on here has type r motor so i can relate with you guys on the motor.
Old May 11, 2010 | 12:44 PM
92TypeR's Avatar
FSAE
Benson sleeved B18C @ 85mm. Lightened GSR 87.2mm crank.
1979cc
Old May 11, 2010 | 01:20 PM
Dr. DC2's Avatar
im all stock. maybe when she needs a rebuild ill bump the compression and do some head work.
in for others set ups
Old May 15, 2010 | 11:18 AM
anyone using CTR pistons in your ITR motor. how is the results? also i did notice there is some cheap CTR pistons on ebay are they any good. anyone bought any of them before? http://cgi.ebay.com/ebaymotors/Jdm-C...Q5fAccessories
are these real oem CTR pistons?
Old May 15, 2010 | 06:16 PM
92TypeR's Avatar
FSAE
If you want to use Honda cast pistons, use PR3 or P30 pistons on a 1.8L.
They are considerably lighter, do not have a horrible dome design, and will make the same if not more power than CTR's.
Old May 15, 2010 | 07:04 PM
itr1244's Avatar
i made 200 whp and 140 ish tq with ctr pistons with improper tune. could have got more with better tuning.
now i have wiseco pistons in my B20 block
Old May 15, 2010 | 07:28 PM
and thats the only thing that was done to your motor? no head work?
Old May 16, 2010 | 10:24 AM
emotionisdead's Avatar
Very Emergency!!
Yep, I bought the RS Machine P30 pistons for my rebuild. A bump of a .5 point in compression.
Old May 17, 2010 | 09:30 AM
itr1244's Avatar
lol sorry i forgot to mention i have aftermarket cams as well
JDM_home
Jul 19, 2012 10:11 AM
kart_driver
26
Aug 31, 2010 01:07 PM
young geezer
May 23, 2010 06:28 PM
ALL MOTOR EF8
28
Jan 10, 2005 05:42 PM
hungy
Sep 4, 2003 05:51 PM
