100k Maintenance suggestions besides TBelt/wtr pump?
Hi all,
My 2000 EX is at 96k. I changed the timing belt and water pump a bit early to be safe (around 90), but was wondering if there was anything else I should look into preventative maintenance wise?
Not sure what a valve lash is?
Tranny fluid hasn't been changed too recently but I checked it out while changing oil yesterday and it looks very clean. What's the recommended interval?
i know my moms 93 Si change interval on the tranny is 25k. also when you do this make sure to use honda MTF or ive heard alot of good results from gm synchromesh.
valve lash is the space between the rocker arms and the valve stems. it should be checked/adjusted when you do the timing belt. you take the valve cover off and use feeler gauges to check the lash. you should probably get someone thats done it to help you since you seem unsure.
tacchan
Mar 7, 2010 02:21 PM
confucius
Jan 24, 2005 08:08 PM
