Setting Input Sensitivity on JL 500/1. Does This sound right?
Old May 10, 2010 | 09:54 PM
imadigitalgod's Avatar
Default Setting Input Sensitivity on JL 500/1. Does This sound right?
I'm wondering if these outputs sound right when calibrating the input sensitivity on a JL 500/1v2.
Components I have:
1.) Alpine CDA-9813
2.) JL 500/1v2
3.) JL 10W6v2
I see that the chart says while playing a pure 50hz tone at -0db for a 2 ohm load (10W6v2-4) the output should be 31.6 volts with the volume **** at 75% of max (I had it at volume #27).
I set the voltage to 31.6. The thing that doesn't seem right is when i put the volume down one notch to 26, the voltage dropped to 21. Does this sound right or is there something fishy going on?
Old May 11, 2010 | 05:56 AM
audioroach's Avatar
Default Re: Setting Input Sensitivity on JL 500/1. Does This sound right?
nope its correct. every head unit has an output voltage. this can range from 1v to 8v of non-clipped signal. It can be a lot higher with a clipped signal but this also add distortion and possible speaker damage as well.
Alpine deck typically put out max non-clipped signal from 22-24 on the volume. you could set you deck to 23 as the max and adjust the amp accordingly.
Old May 11, 2010 | 09:11 AM
twentyhurtz's Avatar
your Gain is a Multiplier of the input signal. I didn't look up your head unit, but most alpine's have a 4v pre-out. The Analog Pot on the amp just amplifies that input signal via the amplifer. As far as your actual output in Vout, i don't know what the figure would be, but as long as your signal is not clipping your fine.
Old May 11, 2010 | 06:02 PM
fcm's Avatar
fcm
Old Fart
Sounds correct to me. 94
EG6 Poe
Audio / Security / Video
May 26, 2008 08:30 AM
mikeycivic
16
May 23, 2008 06:12 AM
ITB
Oct 25, 2005 12:03 PM
noob with an RS
18
Jan 20, 2005 08:43 PM
Short Fuse
16
Nov 2, 2004 06:55 PM
