FS: B/D Series , EG, DC and EK SUMMER BLOW OUT SALE!!!!!!!!! LOTS OF PARTS
Im cleaning out some parts i dont need from my storage. Im not in a rush to sell any decent offers will be excepted but NO LOW BALLERS. I will accept trades for B series turbo parts and eg8/9 parts. I am located in Tampa in the bucsh gardens area and will not drive more than 10 mile to meet anyone. Paypal and shipping is the buyers responsibilty. For pics go here http://www.tamparacing.com/forums/ho...ots-parts.html
100 OBO - D-series manifold Down Pipe and T25 turbo with NO SHAFT PLAY.
25 OBO Ebay knock off wastegate
75 OBO - LS head need to be assembled but have a fresh shave and everything you need to put it back together. When i was removed it had 80XXX miles
45 OBO - D-Series Power steering Pump Working when removed.
40 OBO - D-Series Rear mount bracket
60 OBO - B-series Rear mount Bracket from a 99 DC2 integra
50 OBO - B series A/C bracket off a 92-95 EG B16 no tensioner pulley
65 OBO - B series A/C bracket off a LS B18b with pulley
50 OBO - B series Altenators from DA integra im not sure if they are OBD 1 or OBD 0 but i am sure they work
50 OBO - OBX Fuel Pressure Regulator with fittings and liquid filled gauge
40 OBO - MSD Extenal coil
25 OBO - 1994-2000 Acura Integra Dual Cluster Bezel Pod. It has a small chip at the top but is not seen once installed
50 OBO - JDM GSR cams needs to be cleaned but are mint
25 OBO - DC2 integra steering wheel no airbag has some wear at top
35 OBO - B16 intake manifold bare and needs to be cleaned up
25 OBO - B series intake pipe
25 OBO - DA intake pipe
40 OBO - oem rear mount eg/dc/ek
40 OBO - BNIB MSD D seires Vtec Distriutor cap for external coil with new gasket
35 OBO - Carbon fiber Spark plug cover for B series Vtec engine
80 OBO - 2000 OEM Acura Integra Power side mirrors
40 OBO - OBD2 P2E ECU
25 OBO - DA oem intake pipe
25 firm - motorcycle battery charger Used once to charge my new battery
50 OBO - Greddy turbo timer wired up but never used.
40 OBO - Starion Intercooler made to work on eg with fog lights has bent fins but was pressure tested to 50 psi and does not leak.
35 OBO - D series Shift linkage with shifter
30 firm - 390 DSM injectors
is this the D series ac bracket into eg with b18? P54? if so i'll take it.
LiL accORd RideR
Aug 20, 2012 09:14 PM
