Honda S2000 Honda S2000
symptoms of a failing clutch
Old May 10, 2010 | 12:39 PM
SYTFU Tommy.'s Avatar
Default symptoms of a failing clutch
just started to happen today, drives fine without any slipping at all. sometimes hard to get out of 1st gear and reverse only. even with the clutch pedal completely pressed in, the car still feels like the clutch is slightly engaged with a tad of jerking. only very low speed 2<mph in 1st and reverse only. checked the master cylinder which had a slight leak and has been changed. the slave is fine with no leaks at all also. bleed correctly til not no air bubbles are left at all. symptoms of a failing clutch?
732xghost
Dec 22, 2014 09:29 AM
92redhatch
Jan 25, 2008 04:31 PM
ac_attak
Jun 7, 2006 11:12 AM
markski037
Dec 21, 2005 05:13 PM
Greenery18
Jul 8, 2005 04:22 PM
