Valve springs n retainer
Old May 10, 2010 | 08:23 AM
mudd_butt's Avatar
Default Valve springs n retainer
Hi i have left overb16 dual valve springs n retainer will fit my h22
Old May 10, 2010 | 12:50 PM
Rasmusm's Avatar
Default Re: Valve springs n retainer
Yea they will if you are going with the skunk2 Pro2 cams, if only tuner cams get the tuner series springs
Old May 10, 2010 | 02:23 PM
Tunerguy1989's Avatar
Your using stock b16 springs with skunk2 pro 2 is that really safe? Those pro 2 add quite a bit of lift.
Old May 11, 2010 | 10:59 AM
mudd_butt's Avatar
They were s2 springs and retainer but mow I have an h22 no cams yetthoe just wandering if they fit
Old May 12, 2010 | 01:08 PM
Rasmusm's Avatar
Well I emailed Skunk2, because Im going to put in those Pro2 cams this is what they told me:
Thank you for contacting the Helpdesk at Skunk2 Racing.
When installing Pro Series Camshafts in an H22 you will actually be ordering B series Pro Valve Springs (PN 311-05-5350) and a set of spring bases (PN 312-05-0015).
The spring bases make up the difference in length (which is the only difference between B and H springs) so that the B series springs can be installed in your H series.
This valvetrain setup has been tested stable to 11,000 RPM.
I hope that could help? But I dno which b16 springs you have leftover, is it skunk2 ^ ?
tofast4uh22
Apr 29, 2014 06:11 PM
TeggieeTuner
Apr 27, 2012 06:37 PM
futrhondaownr
Oct 12, 2010 07:34 PM
kadidle
Nov 16, 2007 04:40 PM
aeolus
May 6, 2002 12:46 PM
