ej1 left side turn signals are faster than right side
Old May 9, 2010 | 10:12 PM
Iloveyourhonda92's Avatar
Default ej1 left side turn signals are faster than right side
So the whole driver side blinkers are faster than the right side, anyone know why? the guy i bought the car from replaced the blinkers and said that he checked them and didnt know why they were doing that, when i put the HAzard lights on they are in synch, but i was wondering why it blinks so fast.
note: corners/city lights/foglights are also wired into the lighting
Old May 9, 2010 | 10:17 PM
EJeff8's Avatar
Default Re: ej1 left side turn signals are faster than right side
When blinkers blink fast, it either means the bulb is beginning to die or there is a problem in the wiring, which will cause the blinker to blink fast and "notify" you of the problem in a sense. You have to trace the lines from the blinker all the way to the column, I'd assume. Have fun.
Old May 9, 2010 | 10:55 PM
civicsmoke's Avatar
either burnt out bulb or faulty wiring installing corners/city lights/foglights
Old May 10, 2010 | 12:46 PM
lame
Old May 10, 2010 | 01:52 PM
JdMJ0hnny's Avatar
same thing happened to my ef, i found out that i had a burnt wire. could possibly be that.
Old May 10, 2010 | 04:45 PM
epic.fail's Avatar
check to make sure that the correct bulbs are being used..if a wrong bulb is used it can cause the blinker to still work but faster or slower then normal
Old May 10, 2010 | 04:48 PM
EG'SUS's Avatar
That happened to me once.. It was just my ground wire that was a bit loose...
Old May 10, 2010 | 04:52 PM
buster97's Avatar
happen to my coupe too but mine would go from super fast to stop working to working normally ...hahah but found out one ground was loose and just make sure all ur molested wires are covered and wrap correctly no bare wires (sometimes it cause that as well)
goodluck
Old May 10, 2010 | 09:26 PM
damn too bad i didnt wire the **** myself, i woulda done it right ha(well i would of tried my hardest too) ha, ill run thru it this weekend. MY passenger fog light stopped working outta no where, so im going to replace the bulb in the future ha. ordering off ebay for like 5.99.... 5k super white, but i got yellow lenses so they might be really bright? any 1 know if that will work decent? or will it burn the plastic???
Old May 10, 2010 | 09:29 PM
oh that and my horn didnt work when i bought the car, took off the bumper and the **** was unplugged >.<! now i can honk my **** at crazy people that drift into my lane
andyisftw
May 14, 2010 10:55 AM
EL Vap133
Apr 16, 2008 09:06 AM
gtcali
Sep 23, 2005 02:24 PM
eg8000rpm
Apr 27, 2005 12:37 PM
RSVTECDC4
Apr 1, 2004 07:34 PM
