Garage Clean out - phillipsburg NJ.
Old May 9, 2010 | 09:56 PM
nolicense526's Avatar
Default Garage Clean out - phillipsburg NJ.
$10 items
b series axles - leak, good as cores
EF engine compartment fuse box
Flywheel bolt set
Civic EF Right mirror
B series Plastic timing covers, have all 3, 10 bucks each
DA clutch cable
EG stock fuel pump
90-93 front brake pads new
EG windshield washer bottle
DA rear filler panel - red
$20 items
EG left knuckle/hub assembly
DA guauge cluster
DA brake master cyl
DA rear brake lights
EK 97 civic steering wheel and airbag
97 civic ex vtec ecu - p2p
p12 ecu for prelude/accord
front shock forks for EF/EG/EK
Stock b series flywheels
DA rear seat
red 96-98 civic fenders
$30 items
GSR pistons and rods, some cracks around ringlands
ACt street clutch disc b series small splines, used around 10k
Stock style clutch set b series big splines, not sure on brand. 30k
JVC cd player KD-G210
H series log turbo manifold t3/t4
GSR throttle body
B series starter
LS head, complete just needs to be cleaned
CRX si rear sway bar
B series half shaft with male end
Autometer Sport comp boost gauge
Half radiator
Slim Fan
3" bullet style muffler new
Blox FMU
B16 crank
other stuff
brand new b series alternator $80
GSR cams w/gears $70
ACT 6 puck disc only 200 miles for small splined b series trans $60
S1 jdm b16 trans $370
B16 head really clean complete w/ VC dizzy, intake mani, throttle body - $550
EG aftermarket exhaust, great condition. brand looks like bosal, not sure though $200
Ek front seats w/rails $120
B series EF mounts. driverside is Hasport, other 2 are place racing $150
Precision 680cc injectors, not many miles $200
most everything you need to go turbo - ebay t3/t4 almost new, turbonetics wastegate, home made downpipe, small front mount, greddy bov, oil feed line $400
88-91 Civic/CRX JSP carbon fiber hood brand new - $300
call/text 6109058396
Old May 10, 2010 | 08:16 AM
Default Re: Garage Clean out - phillipsburg NJ.
Bump.... Ttt
civic1719
Sep 25, 2017 09:58 PM
jdmkha
Northeast (Sales)
Mar 16, 2016 05:55 PM
ev94eg
May 14, 2012 09:50 PM
ThaCivicAssassin
Mar 22, 2005 04:40 PM
