crower 403
Old May 9, 2010 | 04:06 PM
leem23vtec's Avatar
Default crower 403
I just installed some crower 403 camshatfs for a buddy of mine that he picked up from someone for cheap. My question is should the valves being adjusted to oem spec or otherwise? For some odd reason the cam gear marks are not lined up exactly at TDC, but when i retarded the distributor the marks lined up perfect. However the car runs and has full throttle response and what not without retarding the distributor. All help is appreciated.
Old May 9, 2010 | 05:59 PM
racebum's Avatar
Default Re: crower 403
crower cams really should be degreed with adjustable gears. the one set i used was off compared to oem. next, the lash specs are on the cam card. you can call crower tech support for a copy of the cam card which will have the cam specs and lash.
y-49
Apr 6, 2008 02:15 PM
elmo244
Mar 1, 2005 09:19 AM
CA6VTEC
Feb 15, 2005 01:53 PM
b00sted4dr
Jul 10, 2003 04:55 PM
Mover
Nov 19, 2002 06:40 PM
