Civic/Crx sunroof really weak motor & Power Windows
Old May 9, 2010 | 02:22 PM
BadassEFdriver's Avatar
Default Civic/Crx sunroof really weak motor & Power Windows
So i have a '91 civic & crx si both w/ sunroof it seems to be really weak and i tend to have to push it myself to close..sometimes doesnt wanna work..idk if its cus of a bad motor or the relay is bad? or maybe just the switch but i doubt it could be that. So anyone else have this problem before? what could it be? Also i have another quick question, what would i need to put power windows into my hatch? i know i need lhd handles w/ the power switches..but can i use the motor and window arm off a 4dr ef sedan?? or do i need to use the jdm or edm ones?
Old May 10, 2010 | 08:15 AM
91ef_civic's Avatar
Default Re: Civic/Crx sunroof really weak motor & Power Windows
had that problem with my sunroof its the motor, i swapped it out and it works great now
Old May 10, 2010 | 11:18 AM
crx_si-r's Avatar
Any power window switches will work. Either jdm, edm or usdm. They just wire up differently. You can even run the universal SPAL set up. I have the SPAL set up lying around as well as a set of jdm power window switches. Pm me if your interested.
Old May 10, 2010 | 05:49 PM
How much did the motor cost you? what about for a New one? cus all the motors ive seen our ALL bad. And the jdm handles & switches are for rhd cars, so the main switches would be on the passenger side, unless i can flip it upside down but i doubt the brakcets for the handles would work like that..
wizarddrummer
Sep 4, 2012 10:44 AM
ek_type_r99
Oct 16, 2009 10:09 PM
Z-REX
May 28, 2007 01:55 PM
