which way does the dizzy go?
Old May 9, 2010 | 02:12 PM
crazyboy's Avatar
Default which way does the dizzy go?
i just got done putting my motor together 90 si head on a cx block but are at tdc which way do i put in the dizzy?
Old May 9, 2010 | 02:37 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: which way does the dizzy go?
What kind of question is this... you put it right side up...
Old May 9, 2010 | 03:17 PM
90efhatchic's Avatar
#1 tdc the rotor should point at the bottom left plug wire that is number one
Old May 9, 2010 | 03:51 PM
Klasse's Avatar
Do you mean the rotation of the dizzy? Because the key is offset so it will only go in one way. Just spin the rotor till the dizzy goes in.
Old May 9, 2010 | 05:29 PM
crazyboy's Avatar
ok thanx
crazyboy's Avatar
i hear everybody say this but its untrue, it can go in the right way and 180 degrees also
Old May 9, 2010 | 05:30 PM
crazyboy's Avatar
??? have u smoked yourself retarded?
Old May 9, 2010 | 05:38 PM
Klasse's Avatar
My bad must only apply to b18c
Old May 9, 2010 | 05:46 PM
skracer13's Avatar
It will go in 180 degrees off but with FORCE which should tell you to stop and rotate an additional 180 degrees. FYI Firing order 1-3-4-2
Old May 9, 2010 | 05:49 PM
Jorsher's Avatar
It can go 180 degrees but like the previous poster said you will have to force it, and don't expect the distributor/cam to enjoy it.
If you look you can see a slight offset.
There's only one way the distributor will go on so I'm not sure what you're asking.
Old May 9, 2010 | 06:00 PM
Klasse's Avatar
Yeah dont force it. Itl only need a nudge if its lined up right
B_Swapped93
Apr 9, 2013 09:21 PM
KDvtec5757
Aug 9, 2008 06:07 PM
juanintec
Aug 30, 2007 06:52 PM
airikkCRX
Jul 9, 2005 09:59 AM
Heylookits shawn
Oct 18, 2004 12:28 PM
