Oil consumption
I have this oil consumption issue for a while and i tried to minimize the oil consumption by replacing PVC, Distributor O-ring, Vtec filter, Valve cover gasket so basically fixed all the leaks. The engine still consume about 1 litre of oil every 1000 miles (stock B16A engine). I have pull the cylinder head out and took some pictures, i wonder from the pictures below. Any idea as to where the oil consumed??
Cylinder head
Engine block
Alot of built up from the bad PVC.
The intake port
The exhaust ports have alot of carbon built up. Thanks!!
Cylinder head
Engine block
The intake port
Should have done a leak down test prior to pulling the head, that way you could have known what was wrong and where oil was passing through.
has the motor been apart/head gasket changed before? looks like there's copper spray on the head but not the block deck
I had the head gasket changed once, it was replaced by 2 layer Spoon head gasket. I don't know about the copper spray, maybe my mechanic spray it on last time.
Hardedge
Jan 29, 2008 02:00 PM
